It is currently Fri Aug 22, 2025 9:53 am
PostPosted: Mon Jul 15, 2013 6:50 pm
Here is the latest Luthier Tips du Jour video -The topic is shellac.
This video as well as all my other videos are available via my website http://www.obrienguitars.com/videos/, LMI's website or on Youtube.
Enjoy!
These users thanked the author Robbie O'Brien for the post (total 7): Dave Fifield (Fri Aug 23, 2013 6:48 pm) • Beth Mayer (Thu Aug 22, 2013 12:41 pm) • Luc R Regnier (Wed Aug 21, 2013 6:49 pm) • Stuart Gort (Wed Aug 21, 2013 10:09 am) • Cal Maier (Wed Aug 21, 2013 9:13 am) • Cocephus (Wed Aug 21, 2013 8:11 am) • LanceK (Wed Aug 21, 2013 8:10 am)
PostPosted: Tue Jul 16, 2013 12:16 am
First name: Logan
Last Name: Sarchfield
State: AB
Should you be concerned about the flammability of the shellac and alcohol mix if you are spraying it in a non-explosion proof but well ventilated spray booth? No open flames would be present but non xp fan motors and lights would be on.
PostPosted: Wed Jul 17, 2013 6:40 am
First name: micah
Last Name: medlong
City: parma
State: ohio
Zip/Postal Code: 44129
would you ever use bulls eye spray shellac for a finish?
PostPosted: Wed Jul 17, 2013 8:54 am
I never would because I prefer mixing my own flakes but yes, a spray shellac could be used as a finish if done right.
PostPosted: Wed Jul 17, 2013 8:56 am
One should always be concerned about safety when working with anything flammable.
PostPosted: Wed Jul 17, 2013 11:09 am
Last Name: Hosmer
An interesting thread I followed some years back when I had this same question.
http://forums.finewoodworking.com/fine-woodworking-knots/finishing/spraying-shellac-and-explosion-hazard
Hope it helps.
Always have plenty of sandpaper; it's rough out there!
PostPosted: Tue Aug 20, 2013 7:05 pm
For us Canadians who can't get everclear, what kind of alcohol is good to be used? Is methyl hydrate ok?
PostPosted: Wed Aug 21, 2013 8:01 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I use 99% Isopropyl as recommended by Jeff at supplier Wood Essence in Saskatoon - available in pharmacies as rubbing alcohol, has to be 99%, not 70%
I have been using this for years, seems to work fine.
PostPosted: Thu Aug 22, 2013 12:44 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I read that many of the pre-made shellacs are not de-waxed. I do use this kind of shellac on jigs.
PostPosted: Thu Aug 22, 2013 3:44 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Yep, methyl hydrate works too.
PostPosted: Fri Aug 23, 2013 7:50 am
First name: Rob
City: Cochrane
State: Alberta
Be careful with Methyl Hydrate.
A quote from Canadian Woodworking:
"Methyl hydrate will certainly dissolve shellac but all is definitely not well. Methyl hydrate is a carcinogen and is readily absorbed through the skin. The thin latex or nitrile gloves most people use when finishing will not stop it being absorbed. The Canadian government in all its wisdom does not allow the sale of denatured alcohol in Canada but had no qualms about letting the much more dangerous methyl hydrate to be sold in every hardware and paint store around. I use 99% isopropyl alcohol for shellac work and find it quite satisfactory"
PostPosted: Fri Aug 23, 2013 9:24 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Lee Valley
http://www.leevalley.com/en/wood/page.aspx?p=20107&cat=1,190,42942
Doug
